Large
Area
Maskless
Photopolymerization
Alright, how do we build one?
LAMP Machine
Re: LAMP Machine
http://vimeo.com/105584259
looks like its just some sort of UV light source channeled through a fibre optic to some lenses and then projected onto a thin layer of resin. I guess its sorta like a laser cutter/engraver works. Seems like it would be slow though.
adambx
Re: LAMP Machine
I believe it's a XY moving DLP chip. Otherwise it's a normal top down setup, they changed the resin delivery a bit because of the high viscosity of the ceramic mixture.
So the crucial thing would be to miniaturize a projector to make it fit onto an XY carriage and we're in business xD
Re: LAMP Machine
I see that it's a top-down with a moveable X/Y projector. That's a geometry I know CW can already accommodate. It looks like they are using a secondary resin chamber with a wiper to wipe a layer of the resin from the secondary tank over the surface of the build area. I guess my question is: Does this completely fill up the build area with the resin, or does the resin only stick to the last printed layer?
adambx
Re: LAMP Machine
My guess is that it still fills up completely, the second chamber may be there to constantly mix the resin to keep the ceramic particles in suspension. If you only make it stick to the already printed parts then a meniscus is bound form due to surface tension. imagine a glass slightly overfilled with water, but not spilling yet..
- RobertTit
- Joined: Sun Dec 21, 2014 6:03 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
LAMP Machine
Does anyone know if there is a magazine available in the UK speciffically for Machine Embroidery?
Many thanks.
Gerry
xx
Many thanks.
Gerry
xx
