Another CLIP video
Carbon 3D
adambx
Re: Carbon 3D
So this means we would need the slicer to output the area based on calculating the maximum "blob" area. There won't be much suction force if the projection area is spread over a lot of tiny parts, rather than concentrated in one part.
Maybe it would be possible to add a variable $maxArea that we could use to calculate retraction speed for each layer? Steve?
Frogspasm
- Joined: Sat Mar 28, 2015 2:53 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Carbon 3D
Since the biggest cost of this type of printer seems to be the Teflon AF sheet, I wonder if you could get the same effect by floating the resin on a layer of Perflourocarbon.
http://www.alibaba.com/product-detail/D ... 72383.html
It's a glass clear chemically inert liquid that can be highly oxygenated. If that worked, this could get a whole lot cheaper.
Re: Carbon 3D
I found a supplier of Teflon AF Sheets! and its cheap! For my 500x400mm sheet is only $23!!! Ordered their entire supply.
hegykc
Re: Carbon 3D
Without going into all the speed/surface and whatnot calculations,
you could just go with the slowest settings to get a 25X faster printer and not worry about getting the 100X speed.
