Haven't had a ton of time lately as I took on the super fun project of rewiring my house....
Still waiting on a new screen. Made a plate to hold the screen. I already had a vat larger than the screen. Plan is to use magnets to hold screen to bottom of vat.
Daylight Polymer 3D Printer
nc42
Re: Daylight Polymer 3D Printer
More pics
never mind cant upload... :(
AndersonTa
@AndersonHTa
nc42
Still won't let me upload pictures...
The magnets are on the outside of the screen holder so I don't think there should be an issues. Also as far as I know lcds aren't effected by magnets. Think ipad smart covers.
Sorry for bad pictures...
http://imgbox.com/J1nDM4wa
http://imgbox.com/o3JklLza
http://imgbox.com/zl9fh3eO
dpizzle
- Joined: Wed Aug 13, 2014 6:44 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Looks like photocentric is gonna do an iPad screen printer.
http://www.photocentric3d.com/#!Testing ... 133ba1973e
dpizzle
Kvirre,
I haven't seen this, but have you tried running the power off an alternative source. The site says it draws 1.35A which some USB ports might not be able to handle. I'd try a typical 5V wall adapter (maybe from a phone or something).
Did you upgrade the firmware? I think it requires a driver installed on windows if you did.
Here's the manual if you missed it, may help:
http://www.abusemark.com/downloads/dpadapter_rev1b.pdf
Kvirre
- Joined: Tue Jun 24, 2014 8:14 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Thanks dpizzle, I went through the manual and figured it out.
It needed a brightness-change (yellow mode, fast clicks).
This made the flickering go away.
This solved the issue I had with the one I thought was broken
dpizzle
Congrats! That looks great. I assume the cure time was around a minute like photocentric. A bit too long for my taste, I think i'm gonna modify the backlight on mine. I imagine printers in the near future will just allow you to pop in whatever tablet you have and start printing. Pretty amazing if you think about it.
dragokirov
