I did understand from the post, that this material somehow allows even more air moving through the foil, then FEP does.
So what will happen when we pressurize a FEP vat?
This should allow more air going through the FEP I guess..
And will this be enough, (decreasing exposure times and) eliminate refilling the bottom by retracting the build platform?
So my question is, did someone already tried a double-sided-FEP-pressure vat?
(It's just to much work trying it, while someone else did it already..
I also understand, while pressurizing FEP foil, it will create a 'dome', which is (very) bad for focussing distance and potential needs a different slicer algorithm. But before going into these tweaks, we should know if it works or not..
