Hi all,
What are folks using to clean their flex-vats? I was switching between resins today and tried to clean my vat out and wound up making the whole thing cloudy.
Cleaning FEP
telephone1652
- Joined: Sat Nov 01, 2014 12:57 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Cleaning FEP
it'll be cloudy till you add more resin. If youre not using acrylic for any part of your vat then you can use Isopropyl alcohol 99% to clean it and your printed parts of uncured resin.
telephone1652
Re: Cleaning FEP
And that cloudiness doesn't interfere with the next print?
jkao
Re: Cleaning FEP
I believe that either IPA or additional resin dissolves the cloudiness. Since IPA can be damaging to vats, it may be safer just leave it cloudy. After filling the vat with resin and looking at the underside, the cloudiness seems to disappear.
