Flex bottom VAT
Re: Flex bottom VAT
it works great! printed 2 test prints with them.. 0.05mm z-height, its the next best cheap option
IrgendwerAusIrgendwo
- Joined: Wed Mar 05, 2014 3:48 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Flex bottom VAT
Even if the topic is named "flex bottom VAT" I created a version with a 2mm acrylic bottom (see picture above) as I didn't want the FEP film to sag.
The only problem I'll be facing is how to add the FEP film onto the acryl: du you guys think I can do it via adhesion after removing the protective film or is there another good advise?
...tried a LOT of transparent adhesives at small test stripes but (as expected...) nothing worked well.
Maybe I'll try to "glue" the FEP via sewin machine oil to adhere the acrylic sheet to the fep film: should prevent separation in the middle section- on the boarders the film is compressed between the side walls and the 2mm bottom
Re: Flex bottom VAT
Hard to tell what it is.. so, my mind is not blown.. lol
adambx
Re: Flex bottom VAT
A general question for the FEP guys...how long does it last? Are there similar aging issues when compared to PDMS? I'm not talking about sagging due to excessive stretching but chemical stuff like blurring etc.
Cheers!
Cheers!
Re: Flex bottom VAT
I've printed > 50 prints with on fep film and not problems with it.
i think you can do 100 prints easy with it without any chemical reaction.
dangre
Re: Flex bottom VAT
I have printed at least 30+ parts and could see 100 to be doable. I had no noticeable degradation. I really abused mine and even drove a part 10mm or so into my flex vat with no damage, it just bounced back (I did break my part). 0.005" FEP on a tensioned flex vat, 6" x 6".
- 3dprinter.org.ua
Re: Flex bottom VAT
I did an experiment tray with flexible bottom. I could not use it. When I pour the resin floor of the tank bends down . Platform can not exactly pull over to the bottom of this . Because of this, printing is interrupted. Details does not stick to the platform.
chemstar
Re: Flex bottom VAT
Does anyone have pics for a working flex vat
Iv purchased some fep film from cs hyde and I would love to get 50+ prints out of my next vat
Re: Flex bottom VAT
Hello Chemstar;
May I know? which of the Cs Hyde film you have acquired , and did you buy directly from CS Hyde Company or from any other distributor of their product line. I am in the process of building a flex VAT too, very soon I will be able to share the information.
Sincere Regards
Saeed
Sincere Regards
Saeed
