Electronics board help
You can discuss various control electronics here. RAMPs, Arduinos, Motor Controller boards & etc...
laopa
Re: Electronics board help
Postby laopa » Sat Jun 17, 2017 9:28 pm
Hi Space,
The problem is you are asking a printer board with motor output to control a motor output. This will not work.
PUL+ and PUL- will received the pulse tram and it is limited at 5 volts.
DIR+ and DIR- will received the direction
ENA and ENB is to enable the output.
If you plug an ARDUINO directly to this board, then it will work. but Others no.
Maybe the only board will be RASPBERRY with the driver board from NANODLP.com, and replace the driver DRV8825 by wires and connect your driver.But not sure.
Look at bottom of the page:
https://www.nanodlp.com/download/
Good luck
