Whats needed for a DLP Printer
You can discuss various control electronics here. RAMPs, Arduinos, Motor Controller boards & etc...
johnrpm
Re: Whats needed for a DLP Printer
Postby johnrpm » Wed Dec 18, 2013 5:25 pm
Thanks for the plexiglass tip, I shall try it.
Postby Finhead » Wed Feb 05, 2014 4:46 pm
Not sure if this has been posted before but thought I should if not.
I was looking around for various pieces last night and came across this board since this type of printer only need 2 steppers would this work with a Uno to control what we need? Seems like a super cheap way to go if it will.
Clinton
johnrpm
Postby johnrpm » Wed Feb 05, 2014 6:09 pm
If I am reading the datasheet right the only concern is the amps at 750ma, 2amps is better like pollolu or blueice, or is it iceblue. they have a preset to adjust current so that they can be adjusted to work with your motor without getting too hot, but heatsinks can be added as well or even a fan.
Postby Finhead » Wed Feb 05, 2014 11:31 pm
johnrpm
Postby johnrpm » Thu Feb 06, 2014 4:01 am
For that price, I would get one or two for future projects, you never know.
Protoneer
Postby Protoneer » Tue Mar 04, 2014 2:23 pm
Postby PacManFan » Tue Mar 04, 2014 3:55 pm
Postby Finhead » Tue Mar 04, 2014 4:05 pm
Wonder if there is any way to get it working with a Android tablet? I know there is a version of Pronterface that works with Android but not sure that is of any use.
Protoneer
Postby Protoneer » Wed Mar 05, 2014 5:02 pm
Helmi
Postby Helmi » Sun Mar 09, 2014 9:43 am
I don't think it would be the right way to try to run a desktop on the RPi. Of course it is possible but that is (no matter which OS you use) far away from snappy.
I think looking at or shows how things could go with a low cost Singleboard computer. As slicing is rather cheap (performance wise) for DLP compared to FDM this should also be possible on such a low performance machine. Having a web service instead of a desktop UI gives you the freedom to use whatever client you want to control the machine without having the need to have a desktop-computer right next to it that has to be on and running for the whole print job.
I'm printing FDM stuff on 3 printers with one small linux box using RepetierServer (actually a non public beta currently) for quite a while and couldn't be more happy.
I'm not technical enough to know how you could probably use the HDMI out from the command line without a desktop running but that would save loads of performance as you wouldn't need it.
Frank /
