Makerjuice Waxcast stock.
Where the hell is all the European stock? I'm on my last few drops of Waxcast!
- Joined: Thu Apr 20, 2017 3:31 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Makerjuice Waxcast stock.
Hello colleague, you are using this resin to fuse what kind of material ....
Do you do the casting directly or do it with silicone?
I have 2 liters of this resin .... I did not get good results.
Hi Provin.
I use it mainly for silver or gold direct casting. Where are you not having any success? Is it the printing or casting?
- Joined: Wed Mar 29, 2017 5:47 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi guys
have somebody experience with direct casting of gold. And results? How many ash have this resin? And burnout temperature?
I use funtodoo castable and senertec castable resin and after burning 5 hours on 850 grade of celsius it have many ash and when you are not use vacuum cleaner before casting results are not good. when I clean form, results are good but is to much work.I am looking for full castable resin with good results and acceptable price.
sorry for my english
Karel
Karel
Guys, can you post your queries to the right areas of the subgroups.
Thanks.
Thanks.
- Joined: Mon Jun 22, 2015 6:15 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hey hirenashra,
we do have WaxCast in stock (4L right now).
Please have a look:
Please have a look:
