Can you please share your setting for FunToDo Standard Red and FunToDo Castable?
Thank You
FunToDo Help
Re: FunToDo Help
I would say that with a 3500lm projector (say ACERP1500 with default manufacturer settings) at a distance around 10cm, you obtain good results for 50µm slices and 0.8s<exposure<1.2s, depending of the object volume.
