Resin that doesn't absorb moisture
CaptainBisquick
Postby CaptainBisquick » Sun Feb 28, 2016 2:43 am
I'm using the LittleRP with MakerJuice SF in green, and my prototypes absorb moisture, which causes them to warp. Does anyone have suggestions on an easy fix for this? Would the Made Solid resin be better?
CaptainBisquick
Re: Resin that doesn't absorb moisture
Postby CaptainBisquick » Sun Feb 28, 2016 4:56 am
Has anyone tried this technique with MakerJuice? I'm going to give it a try. Would love to know if this has made a difference for anyone else.
http://shop.madesolid.com/blogs/madesol ... sin-prints
Postby hp_ » Sun Feb 28, 2016 7:55 am
Hi CaptainBisquikc,
thank you for the link, very interesting, I will surely try it out next time i print something and the print feels sticky
cardin1
Postby cardin1 » Sun Feb 28, 2016 2:37 pm
It does work. I've tried with several resin brands. If, instead of water, you use glycerin it's even better.
CaptainBisquick
Postby CaptainBisquick » Mon Feb 29, 2016 4:27 am
Thanks! I just ordered some glycerin. Since the resin absorbs moisture, leaving it in water makes me nervous.
Return to “Resins”
Who is online
Users browsing this forum: No registered users and 1 guest
