Visible Light Resin
Visible Light Resin
I noticed last month that Bucktown Polymers has a new resin that's supposed to cure with both UV and visible light, so I picked up a sample to see if it cures any faster at 405nm than Makerjuice. If so, it might be a good option for everyone out there experimenting with LED modded projectors and LCD printers. I'll let you all know how it goes!
Re: Visible Light Resin
Man, you can either order a 250mL tester or a full 20kG for $900... and I thought their normal 4L minimum sizes were pretty large.
If you get to test the resin, I'd really appreciate if you could try measuring the shrink. I'm not sure that I'd be in for 20kG any time soon, but I'm quite curious about finding some good low shrinkage options.
...I got the tester. XD I mean at $900 that still comes out to only around $50/kg, but yeah...that's a lot of resin! If I get the time I will absolutely test the shrinkage, since I really want some nice material that won't warp as badly as what I've been using. >_<
I'd be very interested in your results.
Hi Glacian22. Any reports on your findings with the visible light cured resin sample? very anxious to give it a go myself...
best of luck...
best of luck...
