Best resin for miniatures
- Joined: Mon Jan 05, 2015 5:32 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hello, I am trying to decide what resin I should get to print miniatures for gaming. I need something that will bend without breaking, as there will be thin parts, such as swords. The miniatures will be handled a lot, and probably dropped a lot. I have been using maker juice sub g (not g+), which breaks too easily. Thank you for any help!
- Joined: Wed Jan 07, 2015 8:00 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Best resin for miniatures
Have you considered casting your models. That will be best of both worlds, in terms of details and strength.
It would be too much work for what I'm trying to do.
Could someone give me a comparison of sub g+ and fun to do standard? My last print had a sword that is about 1mm x 3mm, which broke very easily. I need pieces of this size to be able to withstand bring handled regularly. Any info is very much appreciated!
Unfortunately, I've only ever used MakerJuice G+, so I can't give you a comparison of resins... but I can give your topic a bump!
Have you used G+ for this kind of thing? If you could give me an idea of how strong a sword of the size I described is, I would be very grateful.
Hi Mcguinnessdr
Im the US distributor for the Fun To Do resins, I definitely recommend the Industrial blend for your miniatures, its quite strong and durable. Feel free to send me a pm.
Thanks, was looking at your site anyway . Will probably be buying some pretty soon.
I made a few minis with Makerjuice SF, which has a bit of give to it (SF stands for Snap Fit, I think). It seems OK so far, but I'm not very rough on them.
Thanks. I'm not sure how well paint would hold up on flexible models. Anyway, I bought the FunToDo Industrial blend, so I'll see how that works. I'll post back here with my findings, incase anyone else is interested.
