Bulging effect on top down DlP printer.(solved)
kakapoopie
Re: Bulging effect on top down DlP printer.
Postby kakapoopie » Tue Nov 18, 2014 2:58 pm
Thanks Pomeroy
GUYS! Last night I did a test print with super long settle times (30s) between layers. This helped tremendously...virtually no bulging. Also increased Z height from 30um to 50um which helped the resin settle between layers. I'm thinking about getting some Spot A to test next to try to get these settle times lower. So excited about this :)
PomeroyB
Postby PomeroyB » Wed Nov 19, 2014 12:35 am
How fast is your build time with a 30 second dwell?
kakapoopie
Postby kakapoopie » Wed Nov 19, 2014 3:53 am
About 8 hours for 45mm height
PomeroyB
Postby PomeroyB » Wed Nov 19, 2014 4:06 am
Not terrible... Especially since you're building a 50 microns!
I wonder where you begin to get diminishing returns... Is 15 seconds enough? 10? But how do you measure bulging? Just by looks? or is there some quantitative method?
I might have to do some testing on this... not too keen on the wiper solution.
kakapoopie
Postby kakapoopie » Wed Nov 19, 2014 2:22 pm
Just by eye..mainly things that are straight in the model are now straight (which were bulging before)
Since I'm doing prints overnight, I just set maximum dwell that could fit in 8 hours. I tried 15 s actually and was still getting some bulge, but not as much. It all depends on how viscous your resin is, how thick your Z resolution is and how wide your part is.
I will definitely be trying Spot A LV next since FTD seems pretty thick. Does anyone know of any other good low viscosity resins?
firecardenal
Re: Bulging effect on top down DlP printer.(solved)
Postby firecardenal » Tue Jul 07, 2015 5:01 pm
Return to “Resins”
Who is online
Users browsing this forum: No registered users and 1 guest
