Heated Resin
Kvirre
Heated Resin
Postby Kvirre » Mon Oct 06, 2014 10:15 am
I just bought some SubG+ for my top-down printer.
Since I am not using a wiper or other contraption I worry about surface tension to mess up my prints.
I was thinking of heating the resin, but then there is the question : what temperature would be right?
At first I thought viscosity was correlated to surface tension, but apparently not
http://www.cscscientific.com/csc-cienti ... -Viscosity
Has anyone tried this, and does it make any difference?
gmoneyphx
Re: Heated Resin
Postby gmoneyphx » Wed Oct 08, 2014 6:45 pm
My vat is heated. I did it more for control than viscosity problems. I run it at 100F all the time.
Kvirre
Re: Heated Resin
Postby Kvirre » Fri Oct 10, 2014 9:25 am
gmoneyphx wrote:My vat is heated. I did it more for control than viscosity problems. I run it at 100F all the time.
What do you mean by "control"?
gmoneyphx
Re: Heated Resin
Postby gmoneyphx » Sat Oct 11, 2014 4:10 pm
To eliminate the effect of changing resin properties due to temperature.
Re: Heated Resin
Postby hp_ » Sat Oct 11, 2014 5:41 pm
gmoneyphx,
interesting,
can you share more information on this topic.
different material properties based on temperature.
Cheers,
gmoneyphx
Re: Heated Resin
Postby gmoneyphx » Sun Oct 12, 2014 7:03 pm
Nothing terribly interesting to report. I have this in the garage so the temperature variation can be a bit extreme. I didn't want to work out a perfect sequence and then have a 20 degree difference in temperature screw it up. And in my case (top down) the lower the viscosity the better so I picked 100 degrees as the standard. I ran 120 for a time also with no ill effects.
I was not trying to fix a problem related to viscosity with this higher temperature - just maintain a standard.
Return to “Resins”
Who is online
Users browsing this forum: No registered users and 2 guests
