Resins For Investment Casting
sgraber
Re: Resins For Investment Casting
Postby sgraber » Mon Aug 01, 2016 11:41 pm
Research Chemist
jimmyjackson
Postby jimmyjackson » Tue Aug 02, 2016 2:57 pm
Thank you guys.
How many ours do you cure the rings under the UV light. What wattage of UV do you use ?
Can you also post a picture of the all the way cured model to see the color
thank you
chill74
Postby chill74 » Wed Aug 03, 2016 4:16 pm
cerriousdesign
Postby cerriousdesign » Thu Aug 11, 2016 3:14 pm
I cure my resin with heat, an old heating element, at 200 degrees in a vacuum chamber for 2 hours. Cures the resin all the way through not just on the surface like U.V. does.
James
Postby James » Fri Aug 12, 2016 11:07 am
Interesting. I don't see why the vacuum is needed though. Can you explain this aspect?
chill74
Postby chill74 » Sat Aug 13, 2016 8:58 pm
Test Bracelet Links
WaxCast
R&R Ultravest...
No problems casting WaxCast and these are on the thick side for testing.
Yianni-VJ
Postby Yianni-VJ » Tue Apr 04, 2017 4:01 pm
svs
Postby svs » Fri Mar 23, 2018 2:32 am
from the biggest jewellery casting factory of europe & asia...
