I would appreciate some advice about this issue:
I am currently building a SLA DLP 3D Printer, using as a light source a Dell 2400 MP Projector, I removed the color wheel, but when I remove the squared glass filter which is located in front of the bulb, the projector only lasts around 5 minutes on and then it shut down due to overheating.
I tried to replace the filter with common soda glass with the same geometry, but it breaks after a couple of minutes.
Could anyone help me with this?
Thanks in advance
Overheating Issue, Dell 2400MP Projector
3dprintmex
- Joined: Thu Sep 15, 2016 3:17 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
