http://www.amazon.com/InFocus-IN114-Por ... b_title_ce
I am looking at the following DLP. I have been unable to locate a IN2104.. Amazon is sold out and Ebay only has used units. Here is the specs:
InFocus IN114 features:
•XGA 1024 x 768 Native Resolution
•2700 ANSI Lumens (2200 lumens Eco Mode)
•3000:1 Contrast Ratio
•Average lamp life is 6,000 hours when in Eco Mode and 5,000 hours in normal mode
I am ordering this now. Will this work for a DLP printer?
Jeff
InFocus-IN114
Re: InFocus-IN114
Looks good to me, from what I know, most DLPs will work fine. The things to be aware of are the minimum focal distance/length, and whether or not you'll have to modify the optics to remove any UV coated glass. After a resin test or two, you'll know how well it works.
Re: InFocus-IN114
I have a few old HP and benq projectors, they ae cheap and can be hacked because they are a little bit bigger, newer smaller projectors are so tightly packed its difficult to get at things.
I have made my printer so that I can convert it to top down, but will use a pico projector for that.
