Cheap LED projector
mike111
Cheap LED projector
Postby mike111 » Fri Aug 07, 2015 2:57 pm
Hi all I have been looking at those cheap LED projectors on ebay wondering if it would work.
http://www.ebay.co.uk/itm/Mini-Portable ... 20f1d70097
James
Re: Cheap LED projector
Postby James » Sat Aug 08, 2015 8:56 am
Its Native Resolution is 320 x 240, which is on the small side. It also uses a LCD, which most likely won't transmit much into the UV wavelength so you may need to use a resin that can polymerize via wavelengths greater than 410 nm.
jose
Postby jose » Mon Jan 11, 2016 4:25 pm
I too have been looking for my project LCD projectors printer, and from what I have read out there at a good resolution of a minimum amount of lumens 2300lm and after 10 seconds of exposure it would go sullo 3000lm or more, so I decided to make the laser printer, DLP projectors sodium lamp 3000lm are very expensive for me.
ljkoren
Postby ljkoren » Thu Dec 29, 2016 11:15 pm
I bought a 74$ led projector from ebay, but it doesnt output any uv light, anyone know any hacks for this?
Leinad78
Postby Leinad78 » Tue Jan 03, 2017 3:56 am
