7" Raspberry Pi LCD screen, unfortunally not usable
Leinad78
Postby Leinad78 » Wed Mar 25, 2015 12:26 pm
Just a little confirmation for you guys, i tried a cheap 7" screen (http://www.aliexpress.com/item/Original ... 7.html?s=p) from a Raspberry Pi to blow some uv light through it, but the lcd blocks pretty much all uv light. I tried several lamps and leds and no success. I even ripped to polarizers from both sides as i know they sometimes have uv blocker, but as it has a led backlight, there was no uv blocker on the foil. So i tried the bare lcd screen und pushed some uv light on it and even then i didn´t got uv light on the other side.
I know this system is working in general as i used a 17" with ccfl backlight back in the days to verify the combination. I´ll try to find another cheap one and test it, but this time with ccfl backlight.
Re: 7" Raspberry Pi LCD screen, unfortunally not usable
Postby Phife » Wed Mar 25, 2015 12:43 pm
I think the main problem with color LCD's is the color filters, first off Red and Green completely block any usable light, then the blue filter is going to be tuned to a certain wavelength. Probably around 440-450nm.
Using LED's is pretty much needed, lamps and bulbs dont work and wont give even enough light. No point in trying any light source thats less than 400nm as its going to be blocked by the polarizers and the liquid crystals.
So the next step is finding the right LED wavelength for your LCD so you can pass as much usable light through as you can. Im going to experiment with some 440-450nm LED's and color LCD's to see if I can get it working better. I think the 9.6" Ipad3 LCD is the best candidate as its cheap and high resolution. Im also going to experiment with different optics, I can get the LEDs primary optics made in 60 degree so that might remove the need for secondary lenses like im using now. Normal LED's spread light out in all directions (~120 degrees) Only forward moving light can pass through the LCD so the majority is wasted. Lenses of 60 degrees or less will help a lot in getting more usable light through the LCD.
Leinad78
Postby Leinad78 » Wed Mar 25, 2015 1:09 pm
Interesting :)
If i remember correctly, i cured uv resin through a polarizer at 365nm. I´ll try it again tomorrow and post the results.
hegykc
Postby hegykc » Wed Mar 25, 2015 1:42 pm
You would need to post some exact numbers, so we can exclude any misleading information.
Like if you used sub 400nm leds, you would label the lcd as unusable when if fact it might very well be quite ok, if used with 405nm leds, or 410 or 420 etc.
Or if you used leds without lenses and the light was scattered, also not the lcds fault. The surface size of the resin against how many leds underneath the lcd, also a BIG factor. Power supply and led circuit? Distance of the array from lcd?
Many variables need to be taken into account before dismissing an lcd, it would be a shame if we accidentally move over a solution that could be "it".
Leinad78
Postby Leinad78 » Wed Mar 25, 2015 4:37 pm
Feel free to do whatever scientific test you want :)
http://www.ebay.de/itm/291276290537?_tr ... EBIDX%3AIT
My test worked at a 17" tft and if its not working at another one, its not sufficient for me, regardless wavelenghts etc.
steve.strong
Postby steve.strong » Wed Mar 25, 2015 5:46 pm
I've successfully cured Makerjuice SF Red Resin through the Adafruit 5" raspberry pi display using an array of 3W 410nm LEDs and 60 degree lens (purchased from an ebay supplier)
First test showed roughly 150 microns for a 15 second exposure
anthony.julu
Postby anthony.julu » Wed Mar 25, 2015 6:25 pm
@steve.strong
First up, congratulations on your successful experiments with color LCD.
Care to share what exactly you did? Thanks in advance
steve.strong
Postby steve.strong » Thu Mar 26, 2015 11:26 am
Testing has only been very ad hoc so far. Nothing more than the pulling the backlight panel off of the LCD and propping it up over the LED array (which I'm powering directly off of a 12V line). Used a ziploc bag as a vat floor.
I'll try to get more details posted in the next couple of weeks.
anthony.julu
Postby anthony.julu » Fri Mar 27, 2015 4:39 pm
Can't wait to have your detailed post, Steve!
Leinad78
Postby Leinad78 » Sat Mar 28, 2015 10:16 am
I did another test and even with a 50W led there is no uv light on the other side of the lcd. I can easily push some uv light through an old 17" tft screen with the exact same setup, so this definately won´t work.
