Hi all,
i have been looking for someone who modded their Acer to use a UV LED. No luck yet.
Has anyone tried it? Is there a known solution for bypassing the lamp check?
I would like to mod mine to use UV LED and lens spacer to hopefully get a sharper and more uniform picture at minimum distance.
If you guys have any hints, i'd appreciate it a lot. I will keep this thread updated with information in case someone wants to do it too.
Cheers!
						Acer H6510BD UV LED mod?
				PuffPed
- Joined: Mon Jan 18, 2016 3:11 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Acer H6510BD UV LED mod?
Its' been two years, but just in case, have you found anything?
I'm looking for info about modding projectors to use UV leds.
