Dear all,
I am working on a 3D printer which was self designed and built for the reasons to validate multi material printing using DLP projector - LC 4500-UV (works at 405 nm wavelength UV light at an output power of 2W) from Keynote Photonics. Currently I am using a GUI from Keynote Photonics designed for the projector to project images and Universal Gcode Sender (hence works on GRBL firmware) to communicate with the stepper motors(one for the Z axis and one for the X axis to control the linear vat array) in providing the necessary translations as per the GCode file as obtained from Creation Workshop ( my slicer).
I am using flexvats with FEP films (100 microns thick) and a perforated aluminium build plate and the layers are attaching to the build plate well. The resins I have tested are Spot A resins (SPot LV and Spot GP)
But I am having a lot of issues to get models 3D printed. I have tried printing a cube, cylinder and even other models such as the eiffel tower or the rook. The main issue I see is that there is a whole lot of warpage and curling around the edges making the prints a nightmare!
My question is has someone worked with the similar projector. If so I would like to know what resin did they use and what exposure settings they used to succeed in their models.
I hope I get some help out here because there is almost no related work I could find with LC 4500 used for 3d printing applications. I have been following up this community for a while now and it definitely seems that there is a lot of experience with resin type printers. At the moment I am doubting to find whether the projector can be used for 3D printing at all.
Thank you all in advance and have a great day ahead
Kind Regards
Anish
LC 4500 - UV projector
Re: LC 4500 - UV projector
Hi Anish,
I'm also using the LC4500 (from Wintech Digital). Works like a charm and gives pretty good results.
My experience is that exposing resin too fast increases the chances of curling and heavy shrinkage. For some resins (FunToDo) I reduced the LED current (thus brightness) down to around 60% and expose a little bit longer. This improved the overall performance.
Exposure for 50µm layers is around 300 milliseconds with FunToDo AshGray.
Only go with the pattern mode, disable gamma correction and use a proper compensation mask for unevenness of the optics.
Yours Sincerely,
radi2k
Yours Sincerely,
radi2k
- Joined: Tue Apr 10, 2018 8:09 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi radi2k,
Thanks for your input. I will try out your recommendations. Just one question though, do you also use 8 bit in the Pattern sequence or 1 bit? (for the sliced images)
Kind Regards
Anish
Kind Regards
Anish
Hi Anish,
I use 8bit in the pattern mode.
Regards,
radi2k
Regards,
radi2k
