Hi all I have been looking at those cheap LED projectors on ebay wondering if it would work.
http://www.ebay.co.uk/itm/Mini-Portable ... 20f1d70097
Cheap LED projector
Re: Cheap LED projector
Its Native Resolution is 320 x 240, which is on the small side. It also uses a LCD, which most likely won't transmit much into the UV wavelength so you may need to use a resin that can polymerize via wavelengths greater than 410 nm.
- Joined: Mon Jan 11, 2016 1:18 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I too have been looking for my project LCD projectors printer, and from what I have read out there at a good resolution of a minimum amount of lumens 2300lm and after 10 seconds of exposure it would go sullo 3000lm or more, so I decided to make the laser printer, DLP projectors sodium lamp 3000lm are very expensive for me.
- Joined: Thu Dec 15, 2016 9:18 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I bought a 74$ led projector from ebay, but it doesnt output any uv light, anyone know any hacks for this?
