Hi there,
I did my modifications on the Acer P1283 yesterday but I have some questions
I already put the M4 spacers in the lens and now I can focus in the vat easily.
Should remove the UV filter?
Also, when I move the lens assembly forward 3mm the zoom screw/ring only moves a little bit (4mm) to each side, is the zoom screw/ring needed to set the image up or can I just leave it there at the center and work with the focus ring?
Thanks for your help.
Acer P1283 mods
Mariraja
- Joined: Fri Sep 04, 2015 12:01 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Acer P1283 mods
Hi Nalmedia,
I am using the same projector, haven't got a print yet. Were you able to fix the problem?
With the zoom knob problem, I cut open a little bit on the top so that I can access the zoom knob but I could not find any effective difference on the image with the zoom knob. Leave it at the centre and work on the focus ring. I am using M3 spacers though.
Regards,
Bimmer
Regards,
Bimmer
nalmeida
Re: Acer P1283 mods
I've been printing without problems since then. Can you see a focused image on the bottom of the vat?
Mariraja
Re: Acer P1283 mods
Yeah I focused a image under the vat and I figured I didn't calibrate properly after that it was fine. Got my first print yesterday.
Mariraja
Re: Acer P1283 mods
Yeah I focused a image under the vat and I figured I didn't calibrate properly after that it was fine. Got my first print yesterday. After getting the part did you cure it?
nalmeida
Re: Acer P1283 mods
Yes, I cure it in a uv nailer curer/oven that I bought in a chinese store for $20. It usually takes 20 minutes to cure. It has 4 x 9w uv lights.
