Did anyone try to 3D print with a DLP projector a large piece by moving the projector in X and/or Y for each slice?
I imagine using this method will take a long time to 3D print, but if you are using a low resolution projector, you can focus the beam in a small area, for high resolution, then move the projector in a grid pattern for bigger objects. This will take a long time, but much cheaper than having a high resolution projector.
Or.... did anyone try to put 2 (or more) projectors side by side, to print one object at the same time?
I can't afford an expensive projector, so I am thinking of alternatives? Did anyone find a cheap projector with high resolution?
Moving the projector on X & Y for higher resolution and bigger object
Re: Moving the projector on X & Y for higher resolution and bigger object
have you looked at LCD screens.. those are fairly cheap
radi2k
look at machines from "Prodways" (of france) and "Way2Production" (austria).
Greetings,
radi2k
Greetings,
radi2k
