Still I have not a good quality printing. The reasons were in the z axis, in the resin / forgot to mix it / and in the vat. The main is that the vat is directly on the display and have no distance. I hope today to have a success if I have enough time.
Drago
Open source LCD resin printer
Re: Open source LCD resin printer
[quote="hp_
" but cure times are ~25 seconds per layer
hp[/quote]
As I wrote you, forget everything you know about LCD printers
hp[/quote]
From today
1,5 seconds for 50 microns thickness- poor quality
1 second for 50 microns thickness- started much better but the LCD controller died (((
- Joined: Wed Oct 05, 2016 12:24 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
very interesting project. I will follow your progress
- Joined: Sat Oct 11, 2014 4:39 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Drago, what happened to the special non-sticking film you were developing for the VAT?
It's been such a long time that you shared any updates.
