I post a question on my google+ and people tell me to come here asking for help.
Who can recommend me an open-source, resin 3D printer? Now I could only find form 1+ but it's not open source and those ones like Carbon3D is still not available to buy...better assembled, don't need much DIY works.
please help.
Looking for an SLA/DLP open-source printer
Re: Looking for an SLA/DLP open-source printer
If you don't require a large build area check out the LittleRP. The creator is active on this forum and he has run one of the best Kickstarter campaigns I've ever seen.
I have a mUVe DLP ...
http://www.muve3d.net/press/product/muve-1-dlp/
- Joined: Sat Apr 04, 2015 8:06 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I built SeeMeCNC's DropLit kit and was printing in less than 8 hours.
Nautilus,
Pretty darn good, depending on what you want to print. I think it is just as precise as much more expensive printers and everything is open source so you can print as large as 300mmx230mm (low resolution) or high resolution <30um small prints. The developer is always coming up with improvements.
