I'm really considering building a DLP printer instead of buying one. I've built some 3-axis CNC machines in the past so, I think these 3d printers won't be as (mechanically) complex as the CNC machines so am not afraid to go that route.
First question. What's the positive and negatives of a top-bottom and a bottom-up setup? I know top-bottom would require more resin and a deeper vat container, but most I've seen are small print areas.
Second: what's the limitations of the print area? Projector resolution seems to change the print size. Curious why couldn't we just set the projector further away; does it reduce the light required to cure the resin? I'm aiming to have a 7" x 7" print area but seems like most are in the 5"x3" size?
For those that built their printers, what's the time you've spent to get it up and running? A couple weeks, a couple months? I know it will vary pending on how long you spend on it, skill levels, etc.
questions; print size limitations + top-down vs bottom-down
jkao
Re: questions; print size limitations + top-down vs bottom-d
Resolution will be inversely proportional to size. The highest resolution commonly available projector is 1920 x 1080 pixels.
Your size and resolution will depend on how you distribute those pixels over space.
So if you want 100 micron (0.1mm) XY resolution, you project to 192 mm x 108 mm. For 50 micron resolution, you'd project to 96mm x 54mm, etc...
You can probably achieve the size you want going up to 150 micron resolution, although your maximum printable area will always by 16:9, in proportion to the aspect ratio of the projector.
Light intensity on a given point will go down as area goes up, so your exposure times will get longer as you project bigger.
nicanor76
- Joined: Sun Feb 22, 2015 3:35 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Thanks for the info on resolution, definitely helps explain the basics.
