Water beading issue on resin surface
Cosmo
Postby Cosmo » Tue Dec 23, 2014 2:40 pm
Hi everyone,
I'm having an issue with my top down set up floating funtodo resin on top of salt water. After a few uses I am getting little bubbles of water floating up to the top of my resin. This is driving me crazy because I'm not sure why it is happening and it is causing major issues during prints. Has anyone had this experience?
cncbasher
Re: Water beading issue on resin surface
Postby cncbasher » Tue Dec 23, 2014 2:58 pm
it's probable your salt to water ratio is not enough , or that your water is contaminated , especially if you have used a different resin in the same tank before
make sure the tank is clean using Isopropyl alcohol and make sure the tank is dry , try fresh de-ionised water and fresh salts .
if the salt has been left in an open container before use , it is possible to pick up contaminants , including from your hands , so wear gloves .
