gmoneyphx, on the topic of printed optics..
have a look at this website..
HP
lcd3dprinter
- Joined: Thu Jun 09, 2016 12:34 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: lcd3dprinter
How about the OLO 3D printer:
https://www.kickstarter.com/projects/ol ... 3d-printer
It's using a smartphone to display the image to project the layers
Re: lcd3dprinter
They still haven't delivered on the Kickstarter. I wont hold my breath on that one...
- Joined: Sat Jan 07, 2017 10:27 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: lcd3dprinter
It seems there is nearly a same one posted on aliexpress .
https://www.aliexpress.com/item/High-pr ... 3.1.eXRZlL
- Joined: Tue Sep 06, 2016 7:39 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: lcd3dprinter
I did 5 inches for raspberry.
Re: lcd3dprinter
I found aliexpress amazing 10.1 inches printer which cost only $700 for 11.11 shopping festival .
https://www.aliexpress.com/item/11-11-B ... 02833.html
- Joined: Wed May 09, 2018 3:59 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: lcd3dprinter
Hictop 3D printer?
I just got a Hictop printer and everything works, however, when I print, it only prints 1/4 of the print then it stops. Everything keeps working, the temperatures work, and the LCD says printing. I do not know that is wrong. I am using Cura.
