Top down wins...
gmoneyphx
Re: Top down wins...
Postby gmoneyphx » Thu Feb 13, 2014 1:31 pm
I hollow large parts out before I print them mainly to reduce warpage, but helps on saving resin also.
258cj7
Postby 258cj7 » Thu Feb 13, 2014 4:43 pm
gmoneyphx
Postby gmoneyphx » Thu Feb 13, 2014 6:00 pm
I boolean drain holes in using netfabb. Too hard to automate it would seem. Requires some thought in deciding where to place the holes.
watsonstudios
Postby watsonstudios » Thu Feb 13, 2014 6:15 pm
I also create drain holes but make them after the slice image files are done.
I will open up 10 or 12 slice images and just draw in drain holes in Photoshop. I'll just determine at what level to make the holes and in Photoshop, black out or "cut" through an outer shell to create a hole.
This way, you don't mess with the part's geometry.
Jon
erenaud
Postby erenaud » Tue Mar 25, 2014 11:23 am
______________________
Etienne Renaud
Not quite 3D Printing, but somewhat similar:
darrin3d
Postby darrin3d » Wed Mar 26, 2014 1:33 pm
I use 3/4" x 3/4" x 1/16" aluminum angle to support my build plate. I drilled 1/2" holes every 3/4" or so through both legs of the angle. I drew it up in cad to do some volume calculations and found the following... Over 8" of build height, the displacement of liquid by the arm lowering into the vat works out to just under .010", for the surface area I am working with. Factor this in with the material shrink and I'm calling it a wash. They pretty much cancel each other out. Since top-down requires zero lifting strength to separate the build from the vat, the flimsy little piece of aluminum is plenty strong for this purpose, and displaces almost nothing.
