Super Fast ‘Membrane Based’ 3D
anthony.julu
- Joined: Fri Aug 29, 2014 12:19 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Super Fast ‘Membrane Based’ 3D
Ultimately time will tell. Luckily we won't need to wait for too long for a revelation. The product has been launced. I'm sure we'll have a confirmation soon
sodium
the problem wih these hydrophobic coatings is they are not clear transparent and make the glass blurry, fuzzy, etc ... not good to make prints with fine details. already discussed in other topic.
nc42
Also hydrophobic doesn't necessarily mean low surface energy (ease of release)
Leinad78
Koch Chemie based nano-coating?
broli
- Joined: Mon Feb 09, 2015 12:02 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I wouldn't bet on the fact a nano coating would be very resistant to a a resin that's being cured and releasing considerable heat. The advantage of the nanostructured material is that the nano texture is part of the material itself. As I mentioned in the other post the only companies I can find that perhaps could make/give samples are these two:
http://www.rolith.com/applications/self-cleaning
http://www.telaztec.com/index.html
Aculon Technology: Repellency Coating , Adhesion Promotion Coatings, Particle Treatments - Aculon
http://www.aculon.com/technology.php
http://www.aculon.com/video.php
