Top Down Disadvantages and counterpoints
Large expensive resin tank
Yes, you need more resin with top down systems but with the resins we are currently using nobody is printing large solid parts. Shrinkage/warpage just won't allow it. I would say that 8x8x8 is just about the maximum practical size for any of these systems with 5x5x5 being a good starting point. 5x5x5 vat = approx 2 liters of resin. Who is worried about $100 worth of resin??? Of course if your plan was to build a 24" x 24" x 24" volume printer the resin will cost a fortune. But the resin in the least of your problems in this case.
Viscosity / Leveling issues
The larger issue really is the limited selection of resins with really low viscosity. Absent a wiper you have to wait to allow the resin to settle to your approximate layer thickness between layers. Resins with viscosity of over 250 cps or so make this a slow painful prospect. Luckily we have SubG+ which gives a great compromise between shrinkage and viscosity. The really good DSM resins that have well under 1% shrinkage all have much higher viscosity. Not practical in a wiper free top down system.
Top Down Advantages
For me the ultimate, absolute, unimpeachable advantage - RELIABILITY
If you get good attachment in the first layer(s) to the build platform and you are printing a part that can actually be printed (correct supports etc...) - you can print unattended with confidence. There is close to nothing that can go wrong. Of course I am excluding systemic failures like stepper motor, stepper driver, dlp bulb etc... There is essentially ZERO stress on the part as it builds (system induced - shrinkage is always present). From extensive reading on the B9 and FormLabs forums it would seem that "fire and forget" printing on bottom up systems is a fantasy.
Second big advantage - SIMPLICITY
The vat tilt / release mechanism on bottom up is finicky thing. PDMS/FEP coating - try and find someone who thinks dealing with that is fun.
There will always be specific geometry you can pick that favors one system or the other but I think top down wins. Not trying to start a fight or anything
