I just saw this Instructable about casting metal directly in the printed mould!
http://www.instructables.com/id/3D-Prin ... 73I1K3OJVR
They used the FunToDo industrial blend resin to print the mould and casted Pewter in it.
The Industrial Blend has been tested up to 225C.
The melting point of Pewter is around that temperature (230C) You can get Pewter with a lower melting point.
You might also print some cooling system on it...
This way you can print your own moulds for casting model ship fittings, or your own tin soldiers!
Danny
http://www.funtodo.net
