Since I'm in Canada it seems almost impossible to find a source for either Sylgard 184 or QSil 216 at a reasonable cost with shipping usually being higher than the cost of the product. And the FEP sheets are even more expensive in the log run so I continued the quest.
Ran across this today as I was making a list to order molding/casting supplies. It seems to be about as cheap as the generic version of 184 plus shipping will be almost nothing rolled into my order. Anyone think there would be a reason not to try this out?
Clinton
Sylgard/QSil alternative? **WORKS**
Finhead
zerospace
Re: Sylgard/QSil alternative?
Why not, it seems to have the same specifications, so I think it will work.
Hmmm... You might run into problems related to transmission depending on your photo-curable resin and your light source.
"Ultra-transparent Solaris® provides excellent UV resistance yet allows maximum transmission of light."
This statement means that it will block ultraviolet light.
On the other hand, if it didn't work, you could always find other uses for it around the shop.
Glacian22
In this case UV resistance might mean that it doesn't break down/turn yellow when exposed to UV.
True. True.
I wonder what they mean exactly?
johnrpm
The way I read it, its worth a try, some time ago I used uv clear silicone for vacuum casting, it could be the same stuff, letting UV through, the silicone mould with photo resin inside, was put in a light box to cure, it was faster than the two part stuff and simpler.
The only way is to try it I'm afraid.
Random Precision
Finhead
Hey guys sorry about not posting back.
I bought some and received it on Friday but have not had time to finish my VAT or build plate yet, so haven't been able to try it. I will make sure and post back my findings.
Clinton
Clinton
Finhead
Re: Sylgard/QSil alternative? **WORKS**
Did a real quick test with the printer I'm putting together for a buddy.
Had a pieces of picture frame glass left over from my VAT build, 8X11cm. Mixed up enough Solaris for a 3mm coating and left it to cure over night then heated it to 100 deg for 45min to fully cure it. It is perfectly bubble free did not seem to change the color or clarity of the glass at all.
Tested with a Optoma HD65 1600 lumen projector with color wheel removed, it has 2800 hours on the bulb life is supposed to be 2000 so well past being bright at all. lol I did a mock print with CW for a 10 sec layer time and 2 layers, it worked perfect except the resin was moving so the 2 layers are separating. This was with red Fun To Do resin, the print slid off the plate which I'm sure will change once a real print is set up.
But it does indeed let the light through we need to cure and it seems to be much cheaper than Sylgard and approx on par with Qsil at $75 for a Lt kit or 2.1 pounds, for me being in Canada it's actually 30% cheaper if you factor in the shipping costs. The kit also comes with a primer so it forms a better bond to the glass but not sure that would be useful to this application or not.
